Connection was forcibly closed
Hi Team,
Facing two issues.
  1. Try to run a script with JS OOP way, and getting a metrics initialization error.
  2. The connection was forcibly closed most of the time
ERRO[0032] communicating with browser: read tcp 127.0.0.1:16979->127.0.0.1:16978: wsarecv: An existing connection was forcibly closed by the remote host. category=cdp elapsed=“0 ms” goroutine=30
ERRO[0033] process with PID 24516 unexpectedly ended: exit status 1 category=browser elapsed=“215 ms” goroutine=72
ERRO[0033] Uncaught (in promise) GoError: evaluating JS: read tcp 127.0.0.1:16979->127.0.0.1:16978: wsarecv: An existing connection was forcibly closed by the remote host.
running at github.com/grafana/xk6-browser/api.Page.Title-fm (native)
Guide me on this.
Hi @gerardlj,
For the first issue, as the error message says, metrics should be declared in the init context. You can see what it’s about here: The Test Lifecycle.
For the second issue, we need the see the whole script.
Thanks
thanks, Can you guide me to troubleshoot the second problem?
Also, the environment you’re running it on. Please make sure to include as much detail as possible.
Thanks.
