I’m trying to use the Graylog’s data in ElasticSearch to analyse the data and cross it with others.
But the timestamp isn’t in the correct format and I think that why I have this error :
“SearchPhaseExecutionException[Failed to execute phase [query], all shards failed; shardFailures {[iYywti_LSNKySzszsTnnzA][graylog2_0][0]: SearchParseException[[graylog2_0][0]: from[-1],size[0]: Parse Failure [Failed to parse source [{"size":0,"query":{"bool":{"must":[{"range":{"timestamp":{"gte":"1489558035376","lte":"1489579635376","format":"epoch_millis"}}},{"query_string":{"analyze_wildcard":true,"query":""}}]}},"aggs":{"2":{"date_histogram":{"interval":"10s","field":"timestamp","min_doc_count":0,"extended_bounds":{"min":"1489558035376","max":"1489579635376"},"format":"epoch_millis"},"aggs":{}}}}]]]; nested: IllegalArgumentException[Invalid format: [epoch_millis]: Illegal pattern component: p]; nested: IllegalArgumentException[Illegal pattern component: p]; }{[iYywti_LSNKySzszsTnnzA][graylog2_1][0]: SearchParseException[[graylog2_1][0]: from[-1],size[0]: Parse Failure [Failed to parse source [{"size":0,"query":{"bool":{"must":[{"range":{"timestamp":{"gte":"1489558035376","lte":"1489579635376","format":"epoch_millis"}}},{"query_string":{"analyze_wildcard":true,"query":""}}]}},"aggs":{"2":{"date_histogram":{"interval":"10s","field":"timestamp","min_doc_count":0,"extended_bounds":{"min":"1489558035376","max":"1489579635376"},"format":"epoch_millis"},"aggs":{}}}}]]]; nested: IllegalArgumentException[Invalid format: [epoch_millis]: Illegal pattern component: p]; nested: IllegalArgumentException[Illegal pattern component: p]; }]”
Can you tell me if it’s possible to change the format of the timestamp in Grafana to match the Elasticsearch’s data?
FYI: here’s an example of timestamp I try to use => 2017-03-15 11:11:13.236
Thanks
