Compatibility check finds something that doesn't exist in my project
Hi all, I’m getting an error in my compatibility check workflow that is not part of my project:
1) Changed `PanelPlugin.setPanelOptions` used in `src/module.ts:267`
Parameter type changed:
+ Added - Removed
-declare type PanelOptionsSupplier<TOptions> = (builder: PanelOptionsEditorBuilder<TOptions>, context: StandardEditorContext<TOptions>) => void;
+type PanelOptionsSupplier<TOptions> = (builder: PanelOptionsEditorBuilder<TOptions>, context: StandardEditorContext<TOptions>) => void;
First of all, my module.ts file is only 266 lines, and I also searched for “PanelOptionsSupplier” and it is not anywhere in my file. I also found a GitHub issue that may be loosely related. Other than that, I’m stuck. Can someone help me track this down please?
Hi @ventura I’m still working in the issue you mentioned and it is a bit more complex. Do notice that the compatibility check shouldn’t stop you from building or publishing your plugin.
I am aware of this, but I just wanted to bring it up anyway. Thank you for your attention to this issue!
I’m experiencing a similar issue. Do you have any solutions?
Hey @kholanhtcold and welcome to the foruns.
First, please check out that academo said that
And that’s the solution of this question, so please, if the answer doesn’t apply to you, try creating a new post giving more details on your need ok?
