Compaction error in Loki logs - invalid tsdb path
Hi!
I’ve got Loki running on a Docker Swarm, Loki container has a mounted volume to store the logs/chunks, compaction/retention enabled via the compactor, and everything appears to be working fine. But I keep seeing below repeating errors in the Loki logs, which make me suspicious. They appear to always be referring to the exact same index/tsdb_path.
2024-05-12 23:58:12.842
level=error ts=2024-05-12T21:58:12.842199624Z caller=compactor.go:601 msg="failed to compact files" table=index_19412 err="invalid tsdb path: /loki/tsdb-shipper-compactor/index_19412/fb4747e12b92-1623764091715318708-1677258561"
2024-05-12 23:48:12.882
level=error ts=2024-05-12T21:48:12.882135921Z caller=compactor.go:523 msg="failed to run compaction" err="invalid tsdb path: /loki/tsdb-shipper-compactor/index_19412/fb4747e12b92-1623764091715318708-1677258561"
Any idea/suggestion what causes them, if they are relevant, how to mitigate?
Only suggestions I found so far seem to pointing towards conflicting schema_config, but since I’m only using one, that shouldn’t be the case?
Loki v2.9.4 with attached configuration:
target: all
auth_enabled: true
server:
  http_listen_port: ${HTTP_LISTEN_PORT:-3100}
  http_server_read_timeout: 300s
  http_server_write_timeout: 300s
  log_level: ${LOG_LEVEL:-info}
common:
  instance_addr: ${INSTANCE_ADDR:-127.0.0.1}
  path_prefix: /loki
  storage:
    filesystem:
      chunks_directory: /loki/chunks
      rules_directory: /loki/rules
  ring:
    kvstore:
      store: inmemory
    heartbeat_timeout: 10m
  replication_factor: 1
schema_config:
  configs:
      store: tsdb
      object_store: filesystem
      schema: v12
      index:
        prefix: index_
        period: 24h # The index period must be 24h for the compactor.
ingester:
  chunk_encoding: snappy
  chunk_target_size: 1572864
  chunk_idle_period: 2h
query_range:
  results_cache:
    cache:
      embedded_cache:
        enabled: true
        max_size_mb: 100
compactor:
  shared_store: filesystem
  working_directory: /loki/tsdb-shipper-compactor
  compaction_interval: 10m
  retention_enabled: true
  retention_delete_delay: 2h
  retention_delete_worker_count: 150
limits_config:
  retention_period: ${RETENTION_PERIOD:-30d}
  max_query_lookback: 90d
frontend:
  max_outstanding_per_tenant: 2048
  compress_responses: true
  log_queries_longer_than: 20s
query_scheduler:
  max_outstanding_requests_per_tenant: 32000
Does the file /loki/tsdb-shipper-compactor/index_19412/fb4747e12b92-1623764091715318708-1677258561 actually exist? Can you query for logs during that time frame?
Thanks for your reply. I am probably still somewhat confused about the actual storage structure but no, I see a folder /loki/index/ with other index files in there (which are actual files, not folders?), and I see the folders deletion and retention within /loki/tsdb-shipper-compactor/. Within retention/filesystem/markers I find the timestamp files which seem to relate to my respective logging/retention time window.
Ad/ time frame, if I interpret it correctly, this should be somewhere between June 2021 and February 2023, so way before i started collecting logs.
Think I’ve might have figured it out. Reason could have been a misconfigured old bind mount volume in the docker setup, where old compaction data might have been present. After wiping said volume, the errors seem to no longer appear.
