[community] How to deploy Loki with Promtail and Grafana on Linux - No manual Installation
Dear Community members :wave: ,
I have created this video tutorial on how to use visualize and monitor your logs using Loki :grafana_loki: and Promtail with Grafana :grafana:
You need to check your logs if you are working as a:
  • DevOps Engineer
  • SRE
  • System Adminstrator
  • Engineering Managers
  • Cloud Engineer
  • Tech Support
  • More…
Link to the tutorial:
https://medium.com/@syed_usman_ahmed/installing-grafana-loki-with-promtail-on-linux-via-dnf-rpm-distro-81a0be570224
It contains the guides:
  • Install Loki, Promtail and Grafana via dnf command
    • Keep it Up-to-date installation (simply by using the dnf update command)
  • Configure the services correctly
  • Setting up Loki data source inside Grafana
  • Full demo: Creating Dashboards (Time series and Log Panel) for all the log files
Link to the video
