Is there any common storage medium available in k6?. My usecase is I need to send cookies to each and every request header. Cookies will be set during signin. For each and every workflow I am requesting signin which seems costly. Any workaround in storing the cookies, so that i can access and send to each and every request.
Hi @Asttle
Welcome to the forum. If the website you’re testing allows it, you can get/set the cookies once in setup as a global variable and then simply re-use them in default function. As for the storage medium, there is a cookie jar object which can be used at any level of test execution. Please see the docs:
For example, you can declare global jar object and use jar.cookiesForURL(url) method in setup to get cookies for that url and then set them in http calls. Hope that helps!
