CodeEditor doesn't support typescript/javascript
Currently grafana has removed typescript which causes an error in the console if javascript is used. Is there a way to trick the editor to use javascript without getting the error in the console.
Hi @zuperzee
Can you try explaining your problem again? Are you encountering this error while try to build grafana from source?
I’ve made a PR which will hopefully fix this. Monaco: Add javascript and typescript support by ZuperZee · Pull Request #38703 · grafana/grafana · GitHub</tit
Here is a better explanation if you’re curious CodeEditor using javascript/typescript causes an error in the console · Issue #38700 · grafana/grafana · GitHub
@zuperzee nicely done with the PR! :grafana: :heart:
