I am trying to send a grpc request using k6 and I am getting a timeout with this error:
GoError: context deadline exceeded: connection error: desc = “error reading server preface: http2: frame too large”
Has anyone encountered this issue?
Hi @aviklaiman !
Welcome to the community forums! ![]()
It sounds like the connection issue ![]()
Out of curiosity, does your service require authentification? Is it behind any proxy? Does the issue persist when you try to use another util like grpccurl?
Cheers!
@olegbespalov Hi,
Thanks - managed to solve it.
Hi! How did you solved your issue? We’re facing a similar situation.
do you mind sharing solution? i’m also facing the similar issue.
not sure if i got pass the issue, looks like the error “error reading server preface: http2: frame too large” is misleading, i tried to configure with TLS:
client.connect('<host>:443', { timeout: '5s' })
and then got pass this issue.
however, i’m facing:
unexpected HTTP status code received from server: 464 (); malformed header: missing HTTP content-type
not sure if this is server configuration issue? my but guess is the server doesn’t have application/grpc enabled
