Hi @Mada
From your example, I see a couple of issues.
First, the request( method, url, [body], [params] ) has a body, that in your case should be null.
I ran a curl to get an existing record:
curl https://restful-booker.herokuapp.com/booking/6366
Which returns:
{"firstname":"John","lastname":"Smith","totalprice":111,"depositpaid":true,"bookingdates":{"checkin":"2018-01-01","checkout":"2019-01-01"},"additionalneeds":"Breakfast"}
And changed the test script:
import http from "k6/http";
import { check } from "k6";
export const options = { vus: 1, duration: '1s' }
export default function () {
const res = http.request("GET", "https://restful-booker.herokuapp.com/booking/6366", null, {
headers: { "Accept": "application/json" }
let response = JSON.parse(res.body);
console.log(response);
Which now returns correctly, at least for me:
/ __________ \ |__| \__\ \_____/ .io
execution: local
script: heroku.js
output: -
scenarios: (100.00%) 1 scenario, 1 max VUs, 31s max duration (incl. graceful stop):
* default: 1 looping VUs for 1s (gracefulStop: 30s)
INFO[0000] {"firstname":"John","lastname":"Smith","totalprice":111,"depositpaid":true,"bookingdates":{"checkin":"2018-01-01","checkout":"2019-01-01"},"additionalneeds":"Breakfast"} source=console
INFO[0001] {"firstname":"John","lastname":"Smith","totalprice":111,"depositpaid":true,"bookingdates":{"checkin":"2018-01-01","checkout":"2019-01-01"},"additionalneeds":"Breakfast"} source=console
running (01.1s), 0/1 VUs, 5 complete and 0 interrupted iterations
default ✓ [======================================] 1 VUs 1s
data_received..................: 7.7 kB 6.9 kB/s
data_sent......................: 1.2 kB 1.1 kB/s
http_req_blocked...............: avg=98.15ms min=2µs med=7µs max=490.73ms p(90)=294.44ms p(95)=392.58ms
http_req_connecting............: avg=21.66ms min=0s med=0s max=108.3ms p(90)=64.98ms p(95)=86.64ms
http_req_duration..............: avg=122.13ms min=117.32ms med=119.56ms max=132.98ms p(90)=128.48ms p(95)=130.73ms
{ expected_response:true }...: avg=122.13ms min=117.32ms med=119.56ms max=132.98ms p(90)=128.48ms p(95)=130.73ms
http_req_failed................: 0.00% ✓ 0 ✗ 5
http_req_receiving.............: avg=102.2µs min=43µs med=64µs max=210µs p(90)=186µs p(95)=197.99µs
http_req_sending...............: avg=244.99µs min=9µs med=18µs max=1.15ms p(90)=704.6µs p(95)=927.79µs
http_req_tls_handshaking.......: avg=47.85ms min=0s med=0s max=239.27ms p(90)=143.56ms p(95)=191.41ms
http_req_waiting...............: avg=121.78ms min=117.24ms med=119.49ms max=132.93ms p(90)=128.38ms p(95)=130.65ms
http_reqs......................: 5 4.528666/s
iteration_duration.............: avg=220.69ms min=117.56ms med=122.21ms max=610.75ms p(90)=419.7ms p(95)=515.23ms
iterations.....................: 5 4.528666/s
vus............................: 1 min=1 max=1
vus_max........................: 1 min=1 max=1
There is another issue with this that can be impacting if you were to use nonexistent records. For example:
curl https://restful-booker.herokuapp.com/booking/712124
Which returns a 404 not found:
Not Found%
Would cause the script to return the error you see as well.
The line let response = JSON.parse(res.body); will throw an error when the response has no body.
You should probably add a check there to see the ones that fail. Similar to:
const res = http.request("GET", "https://restful-booker.herokuapp.com/booking/712124", null, {
check(res, {
"status is 200": r => r.status === 200,
if (res.status === 200) {
This will fail if the record does not exist:
And will work if it does:
Finally, note that debugging can be useful when troubleshooting those cases. You would be able to see the http responses and figure out what the issue was.
Let me know if that helps.
Cheers!
