Can't chain variables - Google Cloud Monitoring datasource
I’d like to request an MQL query option when using a Query type variable with the Google Cloud Monitoring datasource. The current version is quite limited using only dropdowns with no ability to chain variables.
v9.3.2
Chained variables using the Google Cloud Monitoring datasource.
Using a Query type variable.
  • What happened?
The Google Cloud Monitoring plugin does not support MQL querying of metrics in the Query type variable.
