Can't add node exporter as a source
Hello. I get an error when i try to add node exporter as a source.
Error:
Error reading Prometheus: bad_response: readObjectStart: expect { or n, but found <, error found in #1 byte of …| <|…, bigger context …| Node Exporter|…
My node exporter URL: http://192.168.0.10:9100
Prometheus config:
scrape_configs:
  • job_name: “node”
    static_configs:
    • targets: [‘192.168.0.10:9100’]
Metrics URL http://192.168.0.10:9100 work fine and show metrics from browser and CURL on prometheus server. Prometheus UI also correct work with this node. But why grafana can’t add this source?
Where is 192.168.0.10:9100 in relation to your prometheus network wise?
What does prom logs say?
