Grafana OSS 9.2.2 -
Access properties from nested objects -
Using infinity datasource to do a POST request. Then using transformations and the query options to access to them. I tried writing $.health.healthStatus in the Rows / Root part of the quwery to get to them but it doesn’t work. Writing $health works but just to get to the first properties, and I need to get to the healthStatus properties of each. I need a sort of table with all those healthStatus per object. I left attached the json example I use and the query. -
What happened?
I can’t access them because it is not an array of objects and I can’t find the way. -
Be able to create a chart I show in the attatched file
Thank you! I didn’t use exactly the same jsonata query but your answer was very helpful because it gave me an idea!!!
