Mac, not sure
- What are you trying to achieve?
I have a metric foo, with a label <state_country>. I want to repeat a panel for each value of state, with all of the values for country per state present in each panel.
- How are you trying to achieve it?
I’ve tried to create a multi-value variable based on the output of label_values(label_replace(, “country”, “$1”, “country_state”, “(.)_(.)”), “country”). I may have reproduced this slightly incorrectly, but I’ve verified that the inner query does work correctly and produces a new label called country.
- What happened?
The result “None” was returned.
I expected to get back a list of values for the new snp label.
There were no errors in the Grafana UI and I do not think that I have access to the logs.
- Did you follow any online instructions? If so, what is the URL?
