Cannot see logs after migration from loki-distributed to loki
Team, I am trying to do migration from loki-dist to loki. My loki has joined the loki-dist cluster and promtail is configured to send logs to both old and new client.
But some how I am not able to see logs from old loki using new data source. The old storage was bolt-shipper and I am trying to use tsdb in new. Below is my configuration
  auth_enabled: false
  podAnnotations:
    sidecar.istio.io/inject: "false"
  commonConfig:
    replication_factor: 1
    # path_prefix: /var/loki
  limits_config:
    # max_query_parallelism by the formula:
    # [queriers count] * [max_concurrent] >= [max_query_parallelism]
    # tsdb_max_query_parallelism: 64 # Default 128
    ingestion_rate_mb: 20
    ingestion_burst_size_mb: 30
    retention_period: 720h
  schemaConfig:
    configs:
      store: boltdb-shipper
      object_store: gcs
      schema: v11
      index:
        prefix: loki_index_
        period: 24h
      store: tsdb
      object_store: gcs
      schema: v13
      index:
        prefix: index_
        period: 24h
  storage:
    type: gcs
    gcs: {}
    bucketNames:
      chunks: sandbox-sandbox-london-b-loki
      ruler: sandbox-sandbox-london-b-loki
      admin: sandbox-sandbox-london-b-loki
  storage_config:
    gcs:
      bucket_name: sandbox-sandbox-london-b-loki
    boltdb_shipper:
      active_index_directory: /var/loki/boltdb-shipper-active
      cache_location: /var/loki/boltdb-shipper-cache
    tsdb_shipper:
      active_index_directory: /var/loki/tsdb-index
      cache_location: /var/loki/tsdb-cache
  # storage_config:
  #   gcs:
  #     bucketnames: -sandbox-sandbox-london-b-loki
  #   boltdb_shipper:
  #     active_index_directory: /var/loki/index
  #     cache_location: /var/loki/cache
  #     cache_ttl: 168h
  #     index_gateway_client:
  #       server_address: dns:///loki-loki-distributed-index-gateway:9095
  #     shared_store: gcs
  #   tsdb_shipper:
  #     active_index_directory: /var/loki/tsdb-index
  #     cache_location: /var/loki/tsdb-cache
  #     cache_ttl: 168h
  #       server_address: dns:///loki-gateway:9095
  #     shared_store: gcs
  # storage_config:
  #   tsdb_shipper:
  #     active_index_directory: /data/tsdb-index
  #     cache_location: /data/tsdb-cache
  # storage_config:
  #   gcs:
  #     bucket_name: -sandbox-sandbox-london-b-loki
  #   boltdb_shipper:
  #     shared_store: gcs
  #     active_index_directory: /var/loki/boltdb-shipper-active
  #     cache_location: /var/loki/boltdb-shipper-cache
  #     server_address: dns:///loki-index-gateway:9095
  #   tsdb_shipper:
  # storage_config:
  #   tsdb_shipper:
  #     active_index_directory: /var/lib/loki/tsdb-index
  #     cache_location: /var/lib/loki/tsdb-cache
  ingester:
    chunk_encoding: snappy
  server:
    grpc_server_max_recv_msg_size: 104857600 # 100 Mb
    grpc_server_max_send_msg_size: 104857600 # 100 Mb
  querier:
    max_concurrent: 8
deploymentMode: SimpleScalable
serviceAccount:
  annotations:
    iam.gke.io/gcp-service-account: sandbox-london-b-loki@-sandbox.iam.gserviceaccount.com
gateway:
  replicas: 2
  resources:
    requests:
      cpu: 100m
      memory: 128Mi
    limits:
      cpu: 200m
      memory: 256Mi
  service:
    labels:
      prometheus.io/service-monitor: "false"
    annotations:
      tailscale.com/expose: "true"
      tailscale.com/hostname: "loki-sandbox-london-b"
  # tolerations:
  #   - key: "dedicated"
  #     operator: "Equal"
  #     value: "observability"
  #     effect: "NoExecute"
  # affinity:
  #   nodeAffinity:
  #     requiredDuringSchedulingIgnoredDuringExecution:
  #       nodeSelectorTerms:
  #         - matchExpressions:
  #             - key: app
  #               operator: In
  #               values:
  #                 - observability
  topologySpreadConstraints:
  - maxSkew: 1
    topologyKey: "kubernetes.io/hostname"
    whenUnsatisfiable: ScheduleAnyway
    labelSelector:
      matchLabels:
        app.kubernetes.io/name: loki
        app.kubernetes.io/component: gateway
backend:
  # podAnnotations:
  #   sidecar.istio.io/inject: "false"
  # podLabels:
  replicas: 2
  resources:
    requests:
      cpu: 200m
      memory: 250Mi
    limits:
      cpu: 400m
      memory: 500Mi
  # tolerations:
  #     operator: "Equal"
  # affinity:
  #   nodeAffinity:
  #             - key: app
  #               operator: In
  #               values:
  #                 - observability
  - maxSkew: 1
    labelSelector:
      matchLabels:
        app.kubernetes.io/component: backend
read:
  autoscaling:
    enabled: true
    minReplicas: 5
    maxReplicas: 20
    targetCPUUtilizationPercentage: 60
  resources:
    requests:
      cpu: 300m
      memory: 1000Mi
    limits:
      cpu: 600m
      memory: 3000Mi
  # tolerations:
  #     operator: "Equal"
  affinity:
    podAntiAffinity:
      requiredDuringSchedulingIgnoredDuringExecution: []
    # nodeAffinity:
    #           - key: app
    #             operator: In
    #             values:
    #               - observability
  - maxSkew: 1
    labelSelector:
      matchLabels:
        app.kubernetes.io/component: read
write:
  autoscaling:
    enabled: true
    minReplicas: 3
    maxReplicas: 10
  resources:
    requests:
      cpu: 200m
      memory: 500Mi
    limits:
      cpu: 300m
      memory: 1000Mi
  # tolerations:
  #     operator: "Equal"
  affinity:
    podAntiAffinity:
    # nodeAffinity:
    #           - key: app
    #             operator: In
    #             values:
    #               - observability
  - maxSkew: 1
    labelSelector:
      matchLabels:
        app.kubernetes.io/component: write
chunksCache:
  enabled: true
  # resources:
  #   requests:
  #     cpu: 100m
  #     memory: 500Mi
  #   limits:
  #     cpu: 200m
  #     memory: 1000Mi
  # tolerations:
  #     operator: "Equal"
  # affinity:
  #   nodeAffinity:
  #             - key: app
  #               operator: In
  #               values:
  #                 - observability
resultsCache:
  resources:
    requests:
      cpu: 100m
      memory: 128Mi
    limits:
      cpu: 200m
      memory: 500Mi
  # tolerations:
  #     operator: "Equal"
  # affinity:
  #   nodeAffinity:
  #             - key: app
  #               operator: In
  #               values:
  #                 - observability
  # TODO: this method is deprecated and will be replaced with other solution
monitoring:
  dashboards:
    enabled: false
  rules:
    enabled: true
    labels:
      release: monitoring
  serviceMonitor:
    enabled: true
    labels:
      release: monitoring
  selfMonitoring:
    enabled: false
    grafanaAgent:
      installOperator: false
# Enable minio for storage
minio:
  enabled: false
# Zero out replica counts of other deployment modes
singleBinary:
  replicas: 0
ingester:
  replicas: 0
querier:
  replicas: 0
queryFrontend:
  replicas: 0
queryScheduler:
  replicas: 0
distributor:
  replicas: 0
compactor:
  replicas: 0
indexGateway:
  replicas: 0
bloomCompactor:
  replicas: 0
bloomGateway:
  replicas: 0
test:
  enabled: false
lokiCanary:
  enabled: false
migrate:
  fromDistributed:
    enabled: true
    memberlistService: loki-loki-distributed-memberlist```
What exactly is the state of your deployment right now?
  1. Do you have one cluster, or two clusters?
  2. Do you have one GCS bucket, or two?
  3. Do you see any log at all, old or new?
I have one namespace in which i have deployed two loki , loki-dist ( old ) , new loki in istio-system ns
I can see old and new logs in loki-dist ( old one ) , I can see new logs in new loki datasource, but why cant I see old logs in new loki datasource
I would check:
  1. Permission of your new cluster.
  2. Compare your configurations between the two clusters and make sure index and s3 buckets are configured the same.
What to check in permission? The loki dist and loki chart is in same cluster. I am using same bucket. What do you mean by index are same? How to check that
Hi @jyotibhanot ,
In my case, I deleted all the boltdb and tsdb* folders, and then I was able to get both logs. Please try this in our local or test environment first.”*
