Cannot create an Issue in GitHub to report bug for xk6-tcp
I have found a bug in xk6-tcp.
I cannot create a new issue in GitHub Grafana xk6-tcp.
GitHub replies
"Error
Unable to create issue."
Here is the bug report
xk6-tcp related panic due to nil passed as tagSet to handleError
k6 with xk6-tcp crash
panic: runtime error: invalid memory address or nil pointer dereference
atlas.(*Node).ValueByKey          atlas.go:45
metrics.(*TagSet).Get             tags.go:56
summary.(*Output).storeSample     summary.go:177   <- sample.Tags.Get(TagCheck)
summary.(*Output).flushSample     summary.go:86
summary.(*Output).flushMetrics    summary.go:79
output.(*PeriodicFlusher).run     helpers.go:69     <- runs every 200ms in its own goroutine
Suggested Patch to tcp/socket_read.go
-	e := s.handleError(err, "read", nil)
+	// currentTags() must be used here (not nil) - handleError ultimately pushes
+	// a metrics.Sample with these tags, and a nil *metrics.TagSet crashes the
+	// summary/dashboard output's periodic flusher...
+	e := s.handleError(err, "read", s.currentTags())
Hi @bernda01,
Welcome to our community forums! :tada:
Thanks for reporting this and apologies for the confusion this might have created.
A colleague has created Panic in periodic metric flusher: `nil` `TagSet` pushed on socket read error · Issue #67 · grafana/xk6-tcp · GitHub, and some folks are reviewing the repo’s configuration for issue creation.
Thanks! :person_bowing:
