I have a question about Promtail. I know I can use Promtail as an HTTP or GRPC server, but can I use Promtail as an HTTPS server?
My case: we’re running a Promtail instance as a proxy server between Promtail clients (thousands of nodes) and Loki cluster. Currently, we use the following loki_push_api configuration
clients:
- url: http://my.loki.server:3100/loki/api/v1/push
tenant_id: random
scrape_configs:
- job_name: loki_push_api
loki_push_api:
server:
http_listen_port: 3100
use_incoming_timestamp: true
The thing is that we want to add one more client and one more scrape config to support both HTTP and HTTPS for security reasons, something like
clients:
tenant_id: random
- url: https://my.loki.server:3101/loki/api/v1/push #let's suppose we're running 2 distributor instances, HTTP and HTTPS under the same hostname, different ports
tenant_id: random_tls
scrape_configs:
loki_push_api:
server:
- job_name: loki_push_api_https
loki_push_api:
server:
http_listen_port: 3101
http_tls_config:
cert_file: /etc/ssl/certs/promtail/cert.pem
key_file: /etc/ssl/certs/promtail/key.pem
I didn’t test it, but I don’t think this will work, because there is no such config option for Promtail
Note the
serverconfiguration is the same as server.
The server block configures Promtail’s behavior as an HTTP server.
My first question of this thread: does Promtail’s server configuration support HTTPS?
If not, then my second question would be: does Promtail’s server configuration support gRPC with SSL/TLS? Something like
clients:
tenant_id: random
tenant_id: random
scrape_configs:
loki_push_api:
server:
- job_name: loki_push_api_grpc
loki_push_api:
server:
grpc_listen_port: 3101
grpc_tls_config:
Also, my third question which is kind of an off-topic: How can I point to one particular client in my scrape_config I want to use?
