What are you trying to achieve? I have a electric power meter, i can read data as electric consumption data
How are you trying to achieve it? My question is: how to write the sql code to calculation the electric consumption in one day and sum up to week, month (for example: today it is 234kwh and next day is 500kwh then total consumption = 500-234 = 266kwh/day and continue…)
What happened?
Hey @phungnguyennghiangoc, welcome to the community.
Sorry to say but your question isn’t really a Grafana question. It would be better if you look for some docs and examples on a SQL forum specifically about your database of choice.
Just to give you some pointers: your query seems like a classic “extract date_part, sum column, maybe where something, group by extracted_date_part” case, so try to work with the logic bellow:
SELECT extract_date_part(date_column, 'month') as "time",
sum(my_column_to_be_summed) as "value",
my_metric_column as "metric"
FROM my_table
GROUP BY time
The code above will not work as in a copy/paste solution. You’ll need to search the right functions of your DBMS and change the columns for your case to make it work.
I wish you good studies.
It is grafana question: i means that i have a electric power meter connected to network and use opc server and sql to put in database as data source with table with 2 column: value (read from power meter) and other column as date.created.
After that using grafana to show this data a number, so my question as i need to help as previous question.
I think that you are clear for my problem. I remember i did read this topic in some where in grafana
Thanks
Nghia
