Best practices we can implement in production
What are the best practices that can be implemented in production server in prometheus and grafana .
I think for any meaningful answer to that question you first of all have to
define “best”.
For example, are you focusing on security, performance, running efficiently on
smaller machines, dealing well with unusually large setups…?
Does your organisation follow specific standards which you are trying to get
Prometheus and Grafana to be compliant with?
The more information you can give about what you are hoping / trying to
achieve, the more likely it is that someone will be able to provide guidance.
Antony.
Mainly looking on performance and running efficiently in machines
