Hello All,
I had a custom variable and am using the same variable as a filter. Based on the selection of the filter the Prometheus query should execute. like if I select one value from a filter some query should not run, and similarly, if I select another value from the filter the same query should execute.
Can we do this?
Thanks & regards,
Bharath Kumar.
