Bad performance with loki
if have an performance issue with Promtail->Loki->Grafana (docker-compose). I start my board in grafana with option "Last 90 Day"s and loki need all Cores (Intel I3) 100% over 10 Seconds, but there are only 1100 log lines (100KB) to read. I mark Timestamp, Logmessage and labled Loglevel with promtail.
Example from Logfile: [2023-05-12 00:31:21,995] INFO: Starting App
promtail-config
    server:
      http_listen_port: 9080
      grpc_listen_port: 0
      log_level: warn
    positions:
      filename: /tmp/positions.yaml
    clients:
      - url: http://loki:3100/loki/api/v1/push
    limits_config:
      readline_rate_enabled: true
      readline_rate: 1000
      readline_burst: 1000
      readline_rate_drop: false
    scrape_configs:
      - job_name: jobnameexample
        pipeline_stages:
          - regex:
              expression: '^(?s)\[(?P<regextimestamp>[^\]]+)] (?P<regextype>INFO|CRITICAL|WARNING)\: (?P<regexcontent>.*?)$'
          - timestamp:
              source: regextimestamp
              format: '2006-01-02 15:04:05,000'
          - labels:
              type: regextype
          - drop:
              older_than: 2160h # 90 Days
              drop_counter_reason: "line_too_old"
          - output:
              source: regexcontent
        static_configs:
          - targets:
              - localhost
          - labels:
              job: jobnameexample
              host: server
              group: backup
              source: logfile
              __path__: /var/log/log.log
loki-config
auth_enabled: false
server:
  http_listen_port: 3100
  grpc_listen_port: 9096
  log_level: "warn"
common:
  instance_addr: 127.0.0.1
  path_prefix: /tmp/loki
  storage:
    filesystem:
      chunks_directory: /tmp/loki/chunks
      rules_directory: /tmp/loki/rules
  replication_factor: 1
  ring:
    kvstore:
      store: inmemory
query_range:
  results_cache:
    cache:
      embedded_cache:
        enabled: true
        max_size_mb: 100
schema_config:
  configs:
      store: boltdb-shipper
      object_store: filesystem
      schema: v11
      index:
        prefix: index_
        period: 24h
ruler:
  alertmanager_url: http://localhost:9093
analytics:
  reporting_enabled: false
limits_config:
  max_query_length: 0h # Default: 721h
  ingestion_rate_mb: 10
  reject_old_samples: false
Loki’s performance comes from distribution. Since you are running on a single instance with local filesystem as storage I don’t think there is much point worrying about or tuning for performance as is.
