Hi Community,
Is there any way we can backup all grafana files automatically? If so, can someone guide me how we can achieve this please.
Thanks.
Hi Community,
Thanks.
I would like to backup all grafana dashboards including datasources, ideally everyday. This should be done in an automated way instead of backing up manually. Any solution for this please?
Welcome @rockythehitman90
Where is your grafana installed on? on bare metal, on your laptop, on a virutal environment?
You could automate this via bash or python or powershell, depends on your environment.
Hi @yosiasz Thank you ![]()
FYI, I am logging in grafana from the URL on windows OS.
That doesn’t answer the question of where grafana is installed but basically you want to do what @sowdenraymond already posted using powershell or python to back up the conf and data folders.
