Authenticating Grafana In an Iframe via Reverse Proxy
    1. Grafana Version: v10.1.4
    2. Operating System: Ubuntu 20.04.6 LTS
  • Embed Grafana in an Iframe with authentication via Reverse Proxy.
  1. We have installed Grafana locally, which is hosted at http://localhost:3000
  2. We have Drawn some Graphs in Grafana and are embedding the same in the React APP
  3. Since we cannot keep the Graphs open for all, we are planning to implement the JWT-based authentication, which is mentioned in the documentation
  4. We are embedding the nginx reverse proxy link in the Iframes,
  5. For now we have hardcoded the auth token in the Nginx, Reverse Proxy and the Graphs loads and embeds fine
  • What happened?
  1. We are passing the auth token to Grafana via Reverse Proxy and subsequently Grafana done some API calls as below and they seem to throw authentication error since the token is not passed to them internally via Grafana (If we hardocode the token for API calls it seems to work).
    • This seems to work fine with url_login approach where a separate token is generated by Grafana and passed for the Subsequent API calls.
API Calls
  • api/dashboards/uid/ac6c1ca8-d858-4687-9a7b-33ee578e47bf
  • api/annotations?from=1675195533000&to=1688198176000&limit=100&matchAny=false&dashboardUID=ac6c1ca8-d858-4687-9a7b-33ee578e47bf
  • api/ds/query
  • api/ds/query?ds_type=mysql&requestId=Q100
  • Grafana should internally send the auth token for the subsequent API calls on its own (as it works for the url_login approach) since we will not be able to identify if the API call has genuinely come from Grafana from Grafana or Postman.
  1. Grafana
allow_embedding = true
[auth.jwt]
enabled = true
header_name = X-WEBAUTH-USER
; jwk_set_file = /etc/grafana/jwks.json
; email_claim = sub
; username_claim = sub
jwk_set_file = /etc/grafana/jwksjson
email_claim = username
username_claim = username
;jwk_set_url = https://foo.bar/.well-known/jwks.json
cache_ttl = 60m
;key_file = public_key.pem
;role_attribute_path =
;role_attribute_strict = false
auto_sign_up = true
url_login = true
;allow_assign_grafana_admin = false
Nginx
http {
	# This is required to proxy Grafana Live WebSocket connections.
	map $http_upgrade $connection_upgrade {
		default upgrade;
		'' close;
	upstream grafana {
		server localhost:3000;
	server {
		listen 99;
		root /usr/share/nginx/html;
		index index.html index.htm;
		# location /api {
		# 	proxy_pass http://localhost:3000/api;
		location /api {
		location / {
			proxy_set_header X-WEBAUTH-USER <JWT_AUTH_TOKEN>;
			proxy_set_header Host $host;
			proxy_pass http://localhost:3000;
		# Proxy Grafana Live WebSocket connections.
		location /api/live/ {
			proxy_http_version 1.1;
			proxy_set_header Upgrade $http_upgrade;
			proxy_set_header Connection $connection_upgrade;
			proxy_pass http://localhost:3000/api/live/;
events {}
For the API calls we are getting Unauthorized error
eg API /api/login/ping we are getting response
message “Unauthorized”
We are expecting Grafana to pass the auth token for all subsequent API calls as this is Grafanas internal functionality.
    yes, all instructions were followed from the official documentation.
  1. Configure JWT authentication | Grafana documentation
Hello we have got the 95% authentication working, we are not able to figure out why Grafana is not sending the auth token for the subsequent API calls, could you please assist on this ?
Believe i have the same issue with anonymous auth and a reverse proxy for the websocket requests, finally got that working now stuck on Failed to authenticate request, user token not found errors in my grafana logs and the websocket request are pending for 5+ minutes. everything containerised but that shouldn’t effect anything. ill keep an eye on this and respond if i figure it out i guess :man_shrugging:
Hey Harry, any luck? I am able to authenticate the original request for the dashboard but the websocket request is stuck pending and sending the failures to the console.
Same as with logs, shows no errors
