Hi team,
I was looking at your documentation re: integrations and I didn’t see the APM tool appdynamics. Do you know if there is support? Or if they support statsd protocol for example?
Thanks,
Shane.
Hi team,
Thanks,
Shane.
Hi there, welcome to the forum ![]()
I don’t have experience with AppDynamics, but from a quick search it appears there is a statsd backend for it: GitHub - Appdynamics/StatsD-Backend: AppDynamics StatsD Backend, enables StatsD metrics to be pushed to a Machine Agent
We haven’t tested or certified this yet, which is why it’s not documented, but in theory it should work with k6’s statsd output.
If you’d be willing to test it out and let us know if it works, we’d consider adding it as an example in the documentation. Thanks!
