Alloy not working for docker logs on VMs
I’m trying to send docker logs using Alloy from remote VM to another VM where loki is running. Does alloy work with loki at all? I do not see any examples for it in repo or documentation
I tried to find examples but not finding any!
Here is the simple config i’m using
logging {
    level = "debug"
    format = "logfmt"
// Discover Docker containers
discovery.docker "containers" {
    host = "unix:///var/run/docker.sock"
// Simple Docker log collection and forwarding
loki.source.docker "docker_logs" {
    targets    = discovery.docker.containers.targets
    forward_to = [loki.write.local_loki.receiver]
// Write to local Loki instance
loki.write "local_loki" {
    endpoint {
        url = "https://vm.com/loki/api/v1/push"
    external_labels = {
        hostname = "{{ ansible_hostname }}",
        source = "alloy",
I’m getting following error
ts=2025-10-20T15:12:23.551413876Z level=warn msg="error sending batch, will retry" component_path=/ component_id=loki.write.local_loki component=client host=vm.com:3100 status=-1 tenant="" error="Post \"https://vm.com:3100/loki/api/v1/push\": context deadline exceeded"
Please help!
I would check and make sure your loki cluster is working and it’s accessible from the URL you specified in the configuration.
Fell into the trap of “it was working yesterday”. Thanks for the quick hint
