All of a sudden all requests from alloy are unauthenticated. No changes were made during the night.
Logs:
ts=2025-05-28T17:21:58.712095839Z level=error msg="Exporting failed. Dropping data." component_path=/ component_id=otelcol.exporter.otlphttp.grafana_cloud error="not retryable error: Permanent error: rpc error: code = Unauthenticated desc = error exporting items, request to https://otlp-gateway-prod-eu-west-2.grafana.net/otlp/v1/logs responded with HTTP Status Code 401" dropped_items=1
ts=2025-05-28T17:22:08.744884902Z level=error msg="Exporting failed. Dropping data." component_path=/ component_id=otelcol.exporter.otlphttp.grafana_cloud error="not retryable error: Permanent error: rpc error: code = Unauthenticated desc = error exporting items, request to https://otlp-gateway-prod-eu-west-2.grafana.net/otlp/v1/logs responded with HTTP Status Code 401" dropped_items=1
ts=2025-05-28T17:22:35.234700598Z level=error msg="Exporting failed. Dropping data." component_path=/ component_id=otelcol.exporter.otlphttp.grafana_cloud error="not retryable error: Permanent error: rpc error: code = Unauthenticated desc = error exporting items, request to https://otlp-gateway-prod-eu-west-2.grafana.net/otlp/v1/metrics responded with HTTP Status Code 401" dropped_items=23
ts=2025-05-28T17:22:36.03677991Z level=error msg="Exporting failed. Dropping data." component_path=/ component_id=otelcol.exporter.otlphttp.grafana_cloud error="not retryable error: Permanent error: rpc error: code = Unauthenticated desc = error exporting items, request to https://otlp-gateway-prod-eu-west-2.grafana.net/otlp/v1/metrics responded with HTTP Status Code 401" dropped_items=2
ts=2025-05-28T17:22:38.440836888Z level=error msg="Exporting failed. Dropping data." component_path=/ component_id=otelcol.exporter.otlphttp.grafana_cloud error="not retryable error: Permanent error: rpc error: code = Unauthenticated desc = error exporting items, request to https://otlp-gateway-prod-eu-west-2.grafana.net/otlp/v1/metrics responded with HTTP Status Code 401" dropped_items=102
ts=2025-05-28T17:22:38.860125571Z level=error msg="Exporting failed. Dropping data." component_path=/ component_id=otelcol.exporter.otlphttp.grafana_cloud error="not retryable error: Permanent error: rpc error: code = Unauthenticated desc = error exporting items, request to https://otlp-gateway-prod-eu-west-2.grafana.net/otlp/v1/logs responded with HTTP Status Code 401" dropped_items=1
ts=2025-05-28T17:22:40.263322185Z level=error msg="Exporting failed. Dropping data." component_path=/ component_id=otelcol.exporter.otlphttp.grafana_cloud error="not retryable error: Permanent error: rpc error: code = Unauthenticated desc = error exporting items, request to https://otlp-gateway-prod-eu-west-2.grafana.net/otlp/v1/logs responded with HTTP Status Code 401" dropped_items=3
ts=2025-05-28T17:23:35.233373937Z level=error msg="Exporting failed. Dropping data." component_path=/ component_id=otelcol.exporter.otlphttp.grafana_cloud error="not retryable error: Permanent error: rpc error: code = Unauthenticated desc = error exporting items, request to https://otlp-gateway-prod-eu-west-2.grafana.net/otlp/v1/metrics responded with HTTP Status Code 401" dropped_items=23
ts=2025-05-28T17:23:36.037715951Z level=error msg="Exporting failed. Dropping data." component_path=/ component_id=otelcol.exporter.otlphttp.grafana_cloud error="not retryable error: Permanent error: rpc error: code = Unauthenticated desc = error exporting items, request to https://otlp-gateway-prod-eu-west-2.grafana.net/otlp/v1/metrics responded with HTTP Status Code 401" dropped_items=2
ts=2025-05-28T17:23:38.447215743Z level=error msg="Exporting failed. Dropping data." component_path=/ component_id=otelcol.exporter.otlphttp.grafana_cloud error="not retryable error: Permanent error: rpc error: code = Unauthenticated desc = error exporting items, request to https://otlp-gateway-prod-eu-west-2.grafana.net/otlp/v1/metrics responded with HTTP Status Code 401" dropped_items=108
Started happening today at around 2am. Can see there has been no ingestion since then as well. API Tokens are still in place with no expiration, Tried replacing the API token with no effect.
