Hi folks,
I am trying to create an alert for dashboard which would trigger when all queries are the same value. Dashboard has 4 Prometheus queries and condition should be - all of them are higher than and equals.
I couldn’t figure it out - Alerting allows creating alert only from one query afaik so I tried to create a query with prometheus binary operators but it doesn’t work for me. Any suggestions? Thanks!
Hello @taxmeifyoucan! You can actually create alert with multiple queries. Check this thread for more information:
Works, thanks!
Pekné nájsť slovákov aj tu!
