Alerting - Labels with dots in the name doesn't return data
Hello
I need send the label’s value from alerts created with elastic search datasource, but when the label name contains dots, for example: kubernetes.namespace, the label return no_value
Anyone knows if are there any way to solve this?
Thanks
Regards
Daniel Vallejo
Hi Daniel,
we had the same problem with the Google Cloud Monitoring Datasource.
The solution was in this post.
I believe in your case it would result in:
{{ index $labels "kubernetes.namespace" }}
Greetings
Julian
Hi Julian,
We have tested the solution and it works!!
Thanks for dedicate your time to help us solve our problem.
Regards,
Daniel Vallejo.
