Additional Azure Regions
I check here (Grafana Cloud availability by region | Grafana Cloud documentation) indicates only westeurope and centralus are available at Azure.
My production k8s cluster is hosted at brazilsouth region of Azure.
I’ve created a different k8s cluster, using OSS versions of Grafana, Cortex, Loki, Tempo, and Peryscope.
I’m thinking to use Grafana Cloud instead of my private cluster.
Any plans to support Brazil region ?
Hi there! You are correct, these regions listed on that page are what’s currently available. However, Grafana Cloud does plan on expanding regions in the future. But the regions and estimated launch dates are currently TBA. Just keep checking that page for any region updates!
