verion 9.20
OEM plugin 4.0 -
I would like to display individual pie chart of filesystems for each hosts in a panel. -
created variables as shown below
What happened?
I would like to display as 1 pie chart for each host. -
Look at the repeat panel option documentation per host
Or try this grafana plugin
