Hi, I am developing a plugin without datasource. Indeed the plugin make ajax request itself and gets its data. I need this behavior because my plugin is interactive and based on user selection it should show different data from server. Now I want to use the field options in showing data but unfortunately because I do not have any datasource and so any input dataframe the field options is empty in override panel . How can I set the field options manually for my panel to see them in override panel.
Related topics
Topic | Replies | Views | Activity | |
Bypass datasource in panel plugin development? | 2 | 348 | June 15, 2020 | |
Adding options to the options buttons | 0 | 538 | November 1, 2017 | |
Can I set/update query editor by using my panel plugin? | 8 | 732 | March 13, 2024 | |
React plugin - How to build panel options based on panel data | 3 | 1231 | October 25, 2020 | |
PanelPlugin.useFieldConfig does not behave as expected | 2 | 868 | December 29, 2022 |
