9.4.3, Ubuntu 22.04, Chrome -
Compute the sum of sparse numeric rows in a table. -
Using the “Add field from calculation” → “Total” transformation. -
What happened?
The “total” operation starts treating “+” as concatenation after there’s an empty cell in the row, even though each column is considered “numeric.”
I also tested cases where, for example, the columns are 10, 5, empty, 5, which results in 155 (it sums 10+5, and then concatenates 5.)
The “total” operation should sum numeric rows, treating empty cells as 0.
What can I do to achieve the expected behavior? I did some transformations on Prometheus data which led to this table having empty cells; is there a way to populate a 0 into those cells instead?
