AD LDAP finds user but "No teams found via LDAP" for some users only
    v9.4.3
    Configure LDAP with Active Directory
    via the ldap.toml file
  • What happened?
    I have set up security groups for LDAP access for Admins. Some members of this group can log in whereas others get “No teams found via LDAP”.
    All members of the security group to have Admin access
# To troubleshoot and get more log info enable ldap debug logging in grafana.ini
# [log]
# filters = ldap:debug
[[servers]]
# Ldap server host (specify multiple hosts space separated)
host = "DC IP"
# Default port is 389 or 636 if use_ssl = true
port = 3269
# Set to true if LDAP server should use an encrypted TLS connection (either with STARTTLS or LDAPS)
use_ssl = true
# If set to true, use LDAP with STARTTLS instead of LDAPS
start_tls = false
# set to true if you want to skip ssl cert validation
ssl_skip_verify = true
# set to the path to your root CA certificate or leave unset to use system defaults
# root_ca_cert = "/path/to/certificate.crt"
# Authentication against LDAP servers requiring client certificates
# client_cert = "/path/to/client.crt"
# client_key = "/path/to/client.key"
# Search user bind dn
bind_dn = "CN=ldap_Grafana Admin,OU=Grafana,OU=Departments,DC=domain,DC=local"
# Search user bind password
# If the password contains # or ; you have to wrap it with triple quotes. Ex """#password;"""
bind_password =
# We recommend using variable expansion for the bind_password, for more info https://grafana.com/docs/grafana/latest/setup-grafana/configure-grafana/#variable-expansion
# bind_password = '$__env{LDAP_BIND_PASSWORD}'
# Timeout in seconds (applies to each host specified in the 'host' entry (space separated))
timeout = 10
# User search filter, for example "(cn=%s)" or "(sAMAccountName=%s)" or "(uid=%s)"
search_filter = "(sAMAccountName=%s)"
# An array of base dns to search through
search_base_dns = ["dc=domain,dc=local"]
## For Posix or LDAP setups that does not support member_of attribute you can define the below settings
## Please check grafana LDAP docs for examples
#group_search_filter = "(&(objectClass=posixGroup)(memberUid=%s))"
#group_search_base_dns = ["OU=Grafana,OU=Departments,DC=domain,DC=local"]
#group_search_filter_user_attribute = "uid"
# Specify names of the ldap attributes your ldap uses
[servers.attributes]
name = "givenName"
surname = "sn"
username = "sAMAccountName"
member_of = "memberOf"
email =  "mail"
# Map ldap groups to grafana org roles
[[servers.group_mappings]]
group_dn = "CN=Grafana-Admins,OU=Grafana,OU=Departments,DC=domain,DC=local"
org_role = "Admin"
# To make user an instance admin  (Grafana Admin) uncomment line below
grafana_admin = true
# The Grafana organization database id, optional, if left out the default org (id 1) will be used
# org_id = 1
group_dn = "CN=Grafana-Editors,OU=Grafana,OU=Departments,DC=domain,DC=local"
org_role = "Editor"
# If you want to match all (or no ldap groups) then you can use wildcard
group_dn = "CN=Grafana-Viewers,OU=Grafana,OU=Departments,DC=domain,DC=local"
org_role = "Viewer"
    When I search for the LDAP user in Grafana LDAP section, I get “No teams found via LDAP”
    No
I cannot find the difference in the user accounts who are able to login vs denied login. I tried copying a user account who is able to login but no luck.
Fix: I gave the bind_dn AD user “Domain Admin” rights and it started working. Will look into the most restrictive permissions instead.
