I’m trying to show several information on a panel with two queries. There is a single panel that works depending on the variable and is repeated for each ip.
Some panels don’t use the second query. When I set up my dashboard, everything went fine. I tried to modify the queries and the panel but nothing changed.
I don’t understand why, thanks in advance.
Here are my queries
Normally there are supposed to be three lines for each panel.
with both queries, normal
a query is missing
