Can someone assist me with creating a panel in Grafana to show the current number of open tickets for Zammad helpdesk (ElasticSearch).
What Timefield variable should I use for the Datasource?
Are you using this guide?
https://docs.zammad.org/en/latest/appendix/reporting-tools-thirdparty/grafana.html
There is section called Not sure about your index names?
which has some tips that might help you.
Your response is not helpful.
Yes I have looked at the documentation, otherwise I wouldn’t be asking on here would I?
The question is how do I create a panel that shows the number of open tickets (created_at - close_at).
I am a beginner at Grafana, ElasticSearch, and Zammad. So a step by step tutorial would be helpful.
Just trying to help and you haven’t said what you have tried - I don’t assume anything when trying to help someone for the first time.
Can I also assume that you have imported the Zammad dashboard that is linked to in the documentation? Zammad: Tickets dashboard for Grafana | Grafana Labs
It contains a panel that shows the number of open and closed tickets.
There is also a Zammad community where you might find more people familiar with Zammad: https://community.zammad.org/
Yes I have that dashboard.,
No it doesn’t show open tickets. It shows the number of created and closed tickets for the last 24 hours. The panel I want is a total of all open tickets (i./e. not Closed or Pending Close).
Yes, I have tried the Zammad forums but got no response there.
