Zabbix-plugin's Installation
Hi, everyone!
I’m trying to install the zabbix plugin for Grafana but I failed.
I followed a installation guide, which is the URL is: Integrando Zabbix e Grafana. Como realizar a integração entre o… | by Peterson Basso | Zabbix Brasil | Medium
I restarted grafana server and when I try to enable the plugin it’s marked to install.
When I tried to install from the button present in the Interface it just says “installation has failed”
I tried to remove and install the plugin through grafana-cli but nothing’s changed.
Could you help me with this?
Could you download this plugin for your operating system from here and just unpack it into Grafana’s plugins folder?
I’ve tried but Grafana can’t recognize the plugin as installed.
Update: I just uninstalled the package on plugins directory and tried to install from Grafana interface. I don’t know why, but now it worked.
Thank you for your help!
