I have a table which in addition to other values also has a “version” column, the versions can vary from totally numeric values (such as 1.03, 14.6, etc) to string values (such as v2.3, 4.0a etc…) when i am trying to insert the version to a link using “override” instead of “1.03” the link receives the value “1” i’ve trying multiple ways to bypass this issue including adding “.text”, “.raw” and “.numeric” to the version variable in the link itself, only “.numeric” seemed to work BUT now the other version like 4.0a do not pass correctly, instead of the version the link displays “NaN”, any one knows solution to this problem? Thanks!
