I would like to create a general panel that shows the health of all my apps in a single panels and show the count of number of app failures.
Example, I have 10 apps monitored in Zabbix, and 3 apps are down. The panel would be able to display the 3 hosts statuses down.
the problem I’m facing right now is, i use the “Trigger” type, but in one app, i may have few scenarios with few triggers.
Example, I have scenarios 1,2, and 3…so happen 2 scenarios down in that same app, so I got 2 triggers, but in actual only 1 app is down. It will confuse some of my audience when they see Number is 2, but app down is actually 1.
