It looks like there is no way to create multiple checks of the same type on the same domain. This is incredibly restrictive.
e.g. You may want two https
checks, one for google.com/foo and another for google.com/bar, both being independent applications.
Unfortunately the way that Worldping functions is that it creates the slug etc based off the host, so you cannot create multiple “endpoints” for the same host, nor can you add multiple checks of the same type to a single “endpoint” (even through the API where checks
are an array).
Can anyone recommend a way around this?
I really don’t want to have to make completely different hosts in order to test through worldping.
