Hi, all!
I need to generate a new id and send back that id generated to the backend in testDatasource.
After sending id to the backend, I need to save that id to the instanceSettings.
Is there any way I can implement this feature?
Hi, all!
Just to clarify, you want to:
Do you generate a new id everytime you call testDatasource? If so, why do you need to store it?
Are you implementing an OAuth flow? In that case, have you looked at the tokenAuth/jwtTokenAuth config?
No, I don’t need to generate id everytime.
Just create an id when the testDatasource is called and save it to the backend/
