I knew in Grafana 4.2, user can’t change pwd if LDAP or authProxy is enabled in profile page,
You cannot change password when ldap or auth proxy authentication is enabled.
</div>```
but my case is using **generic_oauth**, I also wanna forbidden users from changing their pwd, is it okay for me to enable authProxy with empty settings like below as a workaround. any potential issues may occur?
#################################### Auth Proxy ##########################
[auth.proxy]
**enabled = true**
;header_name = X-WEBAUTH-USER
;header_property = username
;auto_sign_up = true
;ldap_sync_ttl = 60
;whitelist = 192.168.1.1, 192.168.2.1
FYI.
https://github.com/grafana/grafana/blob/v4.2.x/public/app/features/org/partials/change_password.html
