Hi all,
I’m using the OSS v8.4.5, why can’t i see the edit/delete icon but only view for the Cortex/Loki alerting? Did i miss any setting?
Thanks a lot!
@evan508 I can’t tell from your screenshot which user type you’re logged in as. If you have anonymous access or another viewer role - it could explain why you’re not seeing the edit button.
Thanks so much for your reply! I login as the admin, I also tried the editor role, it does’t work ![]()
I used Prometheus + Alertmanager + Grafana, why the rues of Prometheus is sorted as ‘Cortex / Loki’ in the ‘Alert rules’ panel, but when I create a new rule , I can’t choose the ‘Cortex / Loki managed alert’ (no datasources found), Does it mean we only can view or edit the existed rules of the Prometheus but can’t create a new one ? I have to add the new rule in the /prometheus/rues.yml ?
here is the datasource I have configured.
Thanks again !
@evan508 I wonder if you clicked the toggle in the datasource configuration to manage alerts via the UI:
@melori.arellano Yes, the screenshot is as below:
after I switch it off it shows “There are no Prometheus or Loki datas sources configured.”
