Why am I unable to perform a Mean Transform over a field parsed by Loki?
I’m using the Grafana 7.5.4 along with Loki 2.1.0. With new Loki queries, I have successfully parsed fields from my logs.
{filename=~"home/data/logs/backup_dag/push_targets/.*/*.log"}
|= "abs.network"
| logfmt
Now I’m trying to apply the following Transforms in the Dashboard pannel with Table visualization selected:
Labels to filedsFilter by name (selected upload field) → Reduce (selected Mean)
For some reason Mean, Min, Max etc don’t work, but First, First(non null), Last, Last(non null) do work.
I kinda have no idea why this is happening though, if I remove the Reduce Transform I seem to have a valid table on which all functions could be applied
Any ideas?
Can’t add more the two images :expressionless: as a new user:
Table dashboard pannel after I remove Reduce:
Hey @rafayak
I think this is more of a question for #support; this question does not appear to be Loki-specific.
I’m curious though why you don’t perform these transformations with LogQL - is there some limiting factor here?
@anon74857911 I got the idea of this from the Loki issues on github. The issue describes a problem similar to mine.
Also, what I’m trying to do s create a metric (a single number) to show in my dashboard
