Use Loki as driver in docker swarm
I took “complete-local-config.yaml” the config from the page with examples of config descriptions: Examples | Grafana Loki documentation, but it doesn’t work
level=info ts=2022-08-20T17:15:04.652695298Z caller=main.go:103 msg="Starting Loki" version="(version=2.6.1, branch=HEAD, revision=6bd05c9a4)"
level=info ts=2022-08-20T17:15:04.654208201Z caller=server.go:288 http=[::]:3100 grpc=[::]:9095 msg="server listening on addresses"
level=info ts=2022-08-20T17:15:04.655636043Z caller=modules.go:736 msg="RulerStorage is not configured in single binary mode and will not be started."
level=info ts=2022-08-20T17:15:04.661435238Z caller=modules.go:863 msg="Not using boltdb-shipper index, not starting compactor"
level=warn ts=2022-08-20T17:15:04.662758989Z caller=experimental.go:20 msg="experimental feature in use" feature="In-memory (FIFO) cache - chunksfifocache"
creating WAL folder at "/wal": mkdir wal: permission denied
error initialising module: ingester
github.com/grafana/dskit/modules.(*Manager).initModule
/src/loki/vendor/github.com/grafana/dskit/modules/modules.go:122
github.com/grafana/dskit/modules.(*Manager).InitModuleServices
/src/loki/vendor/github.com/grafana/dskit/modules/modules.go:92
github.com/grafana/loki/pkg/loki.(*Loki).Run
/src/loki/pkg/loki/loki.go:341
main.main
/src/loki/cmd/loki/main.go:105
runtime.main
/usr/local/go/src/runtime/proc.go:255
runtime.goexit
/usr/local/go/src/runtime/asm_amd64.s:1581
level=error ts=2022-08-20T17:15:04.674104623Z caller=log.go:103 msg="error running loki" err="creating WAL folder at \"/wal\": mkdir wal: permission denied\nerror initialising module: ingester\ngithub.com/grafana/dskit/modules.(*Manager).initModule\n\t/src/loki/vendor/github.com/grafana/dskit/modules/modules.go:122\ngithub.com/grafana/dskit/modules.(*Manager).InitModuleServices\n\t/src/loki/vendor/github.com/grafana/dskit/modules/modules.go:92\ngithub.com/grafana/loki/pkg/loki.(*Loki).Run\n\t/src/loki/pkg/loki/loki.go:341\nmain.main\n\t/src/loki/cmd/loki/main.go:105\nruntime.main\n\t/usr/local/go/src/runtime/proc.go:255\nruntime.goexit\n\t/usr/local/go/src/runtime/asm_amd64.s:1581"
* Terminal will be reused by tasks, press any key to close it.
where can I find a full working config for Loki for local data storage?
I’m new to this - I just wanted to use it by setting the default configuration, but it doesn’t work and reading the configs won’t help me much because I’ll need to study the whole product
with the config that you offered me, grafana does not see container logs, although they are there (with the old config it shows them but not store in db)
but with my configuration from the previous version, which does not save data to disk, logs are present
it would be great if the project had a folder with compose and a working config so that you could run it anywhere without external dependencies (only Loki Prometheus and Grafana) and without additional study of the documentation
