Hi all!
I have a question about using an external mysql database in the custom.ini config file. When I choose to use an external MySQL database (in my case an azure hosted one) instead of the default one, the error logs complain about the root CA cert path being not found when the app refuses to start up.
Where are valid places I can store this cert on a windows machine so that the app can see it? Can i store them outside the built-in windows cert store? I’m assuming that I’ll need these other ones here filled in also. Can i get some examples of where to store + structure the file path in the config to avoid future errors?
ca_cert_path =
client_key_path =
client_cert_path =
server_cert_name =
