What is wrong with my configuration file?
Probably means one of those events is not happening, or the event ID you looking for is not under Security because it’s working on my pc :blush:
Thanks again.
I guess not. Can you share the complete configuration?
I am using your own config, the only thing I changed was the xpath
Thanks again.
So, your configuration is as follows:
loki.process "windows_event_logs" {
	forward_to = [loki.write.default.receiver]
	stage.regex {
		expression = ".*EventID=\"4660\".*SubjectUserName=\"(?P<username>[^\"]+)\".*ObjectName=\"(?P<file>[^\"]+)\".*ObjectType=\"(?P<folder>[^\"]+)\".*Computer=\"(?P<hostname>[^\"]+)\".*IpAddress=\"(?P<ip_address>[^\"]+)\".*TimeCreated=\"(?P<timestamp>[^\"]+)\".*"
	stage.labels {
		values = {
			file       = "file",
			folder     = "folder",
			hostname   = "hostname",
			ip_address = "ip_address",
			timestamp  = "timestamp",
			username   = "username",
	stage.timestamp {
		source = "timestamp"
		format = "RFC3339"
loki.relabel "windows_event_logs" {
	forward_to = [loki.process.windows_event_logs.receiver]
	rule {
		source_labels = ["__name__"]
		target_label  = "__name__"
loki.source.windowsevent "windows_event_logs" {
	eventlog_name          = "Security"
  xpath_query            = "*[System/EventID=5061] or *[System/EventID=5379]"
  poll_interval          = "0s"
  use_incoming_timestamp = true
	forward_to             = [loki.relabel.windows_event_logs.receiver]
	labels                 = {
		job = "windows_event_logs",
	legacy_bookmark_path = "./bookmark.xml"
loki.write "default" {
	endpoint {
		url = "http://192.168.1.2:3100/loki/api/v1/push"
	external_labels = {}
Are you only getting logs for IDs 5061 and 5379 on the Loki server?
