What is the parameter to add into telegraf config file to get VMware virtual machine guest OS version?
what is the parameter to add into telegraf config file to get VMware virtual machine guest OS version?
I was able to import the dashboards but none of the dashboards has VM guest OS version. Is it possible to tweak the config file in telegraf?
