I’m working on decreasing the size of our Grafana container and would like some guidance on what I should consider including in my final build. Currently, my last step looks like this:
# Create final stage containing only required artifacts
FROM scratch
ENV SRC_DIR=/go/src/github.com/grafana/grafana/
WORKDIR $SRC_DIR
COPY --from=build $SRC_DIR/conf ./conf
COPY --from=build $SRC_DIR/public ./public
COPY --from=build $SRC_DIR/bin/grafana-server ./bin/grafana-server
EXPOSE 3001
CMD ["./bin/grafana-server"]
conf for custom configurations public for scripted dashboards and front-end customizations
and the grafana-server binary
Should I be including any other paths in my final build?
