We tried to use webview to access a dashboard with http header, but it couldn't return proper content
    Grafana 8.5.0. Android R and iOS 15.4
    I’m using a webview to load the dashboard url with the http header.
    In iOS, i’m using URLRequest to add Authorization before URL loading
let webView = WKWebView()
var request = URLRequest(url: url, cachePolicy: NSURLRequest.CachePolicy.reloadIgnoringLocalAndRemoteCacheData)
request.setValue("application/json", forHTTPHeaderField: "Accept")
request.setValue("application/json", forHTTPHeaderField: "Content-Type")
request.setValue("Bearer xxxxx", forHTTPHeaderField: "Authorization")
webView.load(request)
In Android, i’m using HashMap to add Authorization before URL loading
private Map<String, String> extraHeaders =  new HashMap<String, String>();
extraHeaders.put("Accept", "application/json");
extraHeaders.put("Content-Type", "application/json");
extraHeaders.put("Authorization", "Bearer xxxx");
mWebView.loadUrl( url, extraHeaders);
  • What happened?
    It always return “Access denied to this dashboard”. But it’s fine if we use the Chrome to browse the URL with header. We have no idea why the webview from Android and iOS cannot accesss properly.
    We expect to see the proper dashboard after giving the http header.
    The dashbaord is not set up by us. So we don’t have the configurations.
    No.
    No.
Finllay, we found the problem. Because there are a lots request in Grafana. So we couldn’t kust write a header for the original URL. That the reason why we couldn’t log in successfully.
For example, there are some URLs in the page.Like picture or data. We have to write the header as well so that the page can be work properly.
