Has anyone implemented VCF monitoring with Grafana? I couldn’t find any relevant documentation or references on this. Any insights, recommendations, or pointers would be greatly appreciated.
The VCF is several components (vCenter/ESXi, vSAN, NSX, SDDC Manager), so you monitor each layer separately and combine them in Grafana.
vSphere (hosts, VMs, datastores, vCenter)
Grafana Cloud: install the vSphere integration (Connections → vSphere). It uses Grafana Alloy and includes pre-built dashboards and alerts. Set the vCenter statistics collection level to at least 2, otherwise key metrics are missing.
Self-hosted: use Telegraf’s inputs.vsphere (requires vSphere 7.0+) pointed at https://<vcenter>/sdk, output to Prometheus, Mimir or InfluxDB, and import a dashboard such as
vSAN
Telegraf’s vSphere plugin can collect vSAN metrics, but they are disabled by default. Remove the vsan_metric_exclude = ["*"] default to enable them.
NSX, SDDC Manager
There are no ready-made Grafana integrations that I know of. Both expose REST APIs, so poll them with Telegraf’s inputs.http or a small custom exporter, store the results in Prometheus or InfluxDB, and build dashboards on top.
Logs
Forward vCenter/ESXi syslog to Loki using Alloy’s loki.source.syslog.
Start with the vSphere layer, then add the other components.
