Vertical Blue Lines in Graph Panel
Hello all,
i would be pleased if anyone could explain me what the blue vertical lines in my graph charts are.
I did not find anything specific within my google searches which helped me.
Grafana 8.1.1
Prometheus 2.27.0
Thanks in advance for any infos what these are or where / how i could look this up.
Greetings Marco
If you click on the small blue indicator at the bottom of each line, do you see a message? If so what does it say?
No message is set.
Just for your info i have following additional things installed.
  • Cloudwatch Datasource
  • Influx Datasource
  • Grafana Image Renderer
I took a look at the grafana logfile.
And i do see events at the same time the notes are added.
t=2021-11-08T13:12:24+0100 lvl=info msg=“New state change” logger=alerting.resultHandler ruleId=63 newState=pending prev state=ok
t=2021-11-08T13:14:08+0100 lvl=info msg=“New state change” logger=alerting.resultHandler ruleId=63 newState=ok prev state=pending
